RNRC
Jul 01, 2018Explorer
The only thing I've come up with is someone had wired this thing up wrong. The module is by the front switch on the generator panel, and it is burned up. There is no 12v power source anywhere around the water pump area. Does anyone out there have any idea where the wiring from the fuse center would be ran so I can use it to the water pump and then I'll mount the module at the water pump area and hook it up like it sounds like its supposed to be wired and let the switches control ground supply to the module. Thanks
38,778 PostsLatest Activity: Jun 07, 2026
