Monkeyrun
Jun 20, 2013Explorer
1999 Allegro BUS 39 Hood Latch Help Please
I recently purchased my Allegro BUS and am in the process of addressing some of the necessary maintenance issues. The hood cable broke loose when I pulled on it, seems the cable is attached to only the passenger side. I'm not certain how the driver side is supposed to be released. It consists of a pin on each side which is spring loaded, that pin then locks into holes in the hinge mechanism to hold it closed.
The hood is now open but I'm uncertain how to tackle this. I can fix the cable most likely but I'm not certain how this operation is supposed to work. If there are any current or former owners of this model, I would sure appreciate some advise. Hopefully I can attach the two pictures I have of the left and right hood lock. The plastic tie wraps are on there just to hold the pins open for now.
