Qualcity's avatar
Qualcity
1999 Ford V10 Loping at Idle (Help)
Hey all,
I have a 1999 Four Winds (Thor) 30Q on what I believe is an F53 chassis with the 6.8L V10. It has developed a loping idle and am undecided as to what to tackle first. There is no check engine light and there are no codes on the computer. When cold and warm will sometimes die right after started, but when running the idle lopes below 1000rpm. It just recently started during a trip up to Steamboat Springs, CO from Denver. I am wondering if the engine braking (sometimes up to 4500rpm) or running down a dirt road for about 9 miles might have gummed up the EGR valve?
I have been doing some research on the symptoms on the net and while several point to the EGR valve, serval others indicate the IAC valve, plugs, wires, coils, bad fuel etc...
I wanted to see if anyone on here might have had a similar issue and what your resolution was, or what some of you more mechanically inclined folk might think about it before I go throwing money at it for things that it might not need. Oh yea, I have about 32K on the motor and am about one year into being the 3rd owner on it.
TIA for your input!
Allen
