Scott & Jill wrote:
Kayteg1 wrote:
First turn the thermostat to heat. When you have it set to 70F and it is 75, the heat will not come.
If thermostat operates fine, you need to go to the furnace and start with checking the power.
Post some furnace pictures if you have more troubles.
What if your temp is over 70F in the coach will it turn on or dose it have to be 70F or lower and if so then how can you test them to see if they work?
The numbers were just examples. To call for heat, the thermostat must be set to a temperature higher than the ambient temperature in the RV.
