Deano56 wrote:
John&Joey wrote:
Did you remember to run the toilet also?
yes
You should be good then. FWIW, a few things that often get overlooked is the outside shower and the sink and/or toilet hand sprayer. The hand sprayer part holds a few drops of water and will crack when frozen.
When I use to spend the winters up north (-40f) I took it one step farther and blew out the pink stuff. Don't think you need to do that in IL, but a Camco air plug is $3 at Walmart, and the amount of time it takes is about 5 minutes with an air compressor. Doing both those things I never had any issues whatsoever even with the extreme cold.
