Bumpyroad wrote:
Deano56 wrote:
Bumpyroad wrote:
evidently you have no water heater bypass nor winterizing pick up fitting. I would suggest getting both before you have to do this again.
bumpy
I'm assuming that fitting should be by the water heater, I see a valve of some sort that has a wire ring that you would put your finger through and pull up on, a pressure relief valve? Other than that I will do some more looking. I did not even think about the hand sprayer for the toilet, better take care of that.
no check out the pictures at "hot water heater bypass valave on 2014 Thor challenger "
bumpy
no bypass system on my WH, I will invest in that
