Deano56's avatar
Deano56
Explorer II
Oct 20, 2013
1st time winterizing
I have read some of the winterizing post here and did my first time. I ran the antifreeze through the 12v pump till i saw the pink come out of all faucets, hot and cold sides, the only problem is that I did not blow out the system and at the end I drained the water heater (kind of backwards) will this work or do I have to start all over? I used 4 gallons of the product.
  • You should be fine. Normally, depending on your motorhome, you'd use less antifreeze. Make sure you do the drains so there's some antifreeze in the traps and drain the waste tanks. Also, drain the appliances (ice maker, washer) if you have them.
