- darsbenExplorer IIWell I am late but I just got the rig back from my service center and I asked them about the filter.. My service center which works on trucks said The metal filter is just a flame arrestor. Blow it out with air as long as you run the regular filter in front of it.
- Airstreamer67ExplorerI doubt this is one, but there are air filter setups that have an inner filter portion that serves as something of a "last chance" filter. I believe it is designed to filter the air to some degree should something happen to breach the main filter. However, the theory about the pictured screen serving as a backfire protector seems very plausible.
- JimM68Explorerthe paper filter must be replaced, and should be within the maintenance guidelines set in the manual.
The inner filter, in theory, should never get dirty is the paper filter has always been replaced within schedule.
If you need to clean the inner filter, you'll need some solvent, a hose, and maybe some compressed air. clean it off the vehicle until it is spotless and dry. - BobandShazExplorerMy old 65 ford had dual filters the outer was an oil bath type
- WILDEBILL308Explorer II
Riverrattralph wrote:
WILDEBILL308 wrote:
Yes what Born TO Travel said. Common set up for high dust environments. Get both filters. I even have the same setup on my lawn mower.
Bill
It is not a foam pre filter. Where can you buy the metal filter?
I missed that it was metal. Wash out the metal one with solvent and replace the paper one. The outer metal filter is probably a flame or spark retarder to prevent fires from backfiers.
Bill - Spray the metal one with carb cleaner and then blow it out with air compressor.
- RiverrattralphExplorer
MotorPro wrote:
Its not a filter. Its a flame arrester. It is suppose to prevent a fire if it backfires. They are reguired on boats.
That's what I was thinking but on a boat you can take off and clean with soapy water but I since this is fastened to the pan and I am not sure what is inside of the screen I am afraid it may block shut if it gets wet. Someone mentioned it was a charcoal filter to reduce fuel fumes inside. I just can't help but think it has to be replaceable or cleanable since you need the best airflow you can get. - MotorProExplorerIts not a filter. Its a flame arrester. It is suppose to prevent a fire if it backfires. They are reguired on boats.
- ArchHoaglandExplorer
Old-Biscuit wrote:
What are the dimensions of that filter? Height, outer diameter, inner diameter
Screened mesh is to contain backfire from carb.
Here is one by WIX......LINK
I was thinking backfire protection too. - Old-BiscuitExplorer IIIWhat are the dimensions of that filter? Height, outer diameter, inner diameter
38,766 PostsLatest Activity: Jan 10, 2026
