I have 2 new problems this year. First, RV is plugged in with 110, when the furnace shuts off the fridge shuts off also, when the furnace comes back on so does the fridge. How and why are these two th...
If you are plugged into shore power, and your power is cycling on and off, you may have a bad connection in the 12 volt power system somewhere. Start at the batteries and check for 13 volts or more, when plugged in, and go from there.
