usersmanual
Nov 10, 2016Explorer
Kidoo wrote:
Hi, I am about to replace my house batteries. I was reading that connecting 2 x 6 volts in series will double the voltage but not the amps. Connecting 2 x 12 volts in parallel will keep the same 12 volts but double the amps.
For the same price, what is the best solution? I plan on buying the standard acid type batteries at Costco or Sam club.
a pair of standard costco 6 volters= one twelve will have as much amp hour as say two 27Rv 12 volters in some cases.it depends on the 27Rv rate battery u buy but the 2 six volters will only cost $160 approx. and the two 27Rv will cost more in most all cases
now only using a 24RV series battery the two sixes verses 2 24Rv would be the best root both $$$ and amp hour rating
38,768 PostsLatest Activity: Nov 21, 2015
