MrWizard
Nov 10, 2016Moderator
Not a useful comparison
You can't use (3) 6's in an RV, you need two or four
Two sixes is still only 245 amp hrs at 12v
And two 12's will be from 160>210 amp hrs, depending group size and rating
Cheap grp 24 75 amp hrs each
Good grp27 110 amp hrs each
In many cases when going fla batteries, 6v GC give the best results,
Unless you are planning for heavy inverter loads,, then 12 AGM give better results
38,768 PostsLatest Activity: Nov 21, 2015
