usersmanual
Nov 10, 2016Explorer
Kidoo wrote:usersmanual wrote:Kidoo wrote:MrWizard wrote:
Not a useful comparison
You can't use (3) 6's in an RV, you need two or four
Two sixes is still only 245 amp hrs at 12v
And two 12's will be from 160>210 amp hrs, depending group size and rating
Cheap grp 24 75 amp hrs each
Good grp27 110 amp hrs each
In many cases when going fla batteries, 6v GC give the best results,
Unless you are planning for heavy inverter loads,, then 12 AGM give better results
One of my 6 volt AGM battery failed, it read 4.2 and the other reads 6.4. I need some batteries to get me going until I am in USA to buy new ones at Costco or Sam, none available in my Costco. I have two old acid 6 volts, still useable but not very strong, that I want to pair with my 6 volt AGM.
I was planning a tempory installation of 3 x 6 volts to get more juice. Two in parallel and one in series with the two parallel, isn't it possible, I am just about to connect the setup!
no u cant use Three 6 volts at all TWO or FOUR must be used
on a side note buying six volters at Costco in usa will cost u about 116$ cdn;;don't know what its like in Quebec but in BC you can buy Rv six volts for $115.00 cdn so really don't understand your point at all
I just called, they have the Trojan Black box GC225 6volt batteries for $140 each plus tax, total $322. This is the best deal I could get. Where do you get your's, maybe I can find the same store here?
Try someone whom sells NON trojan batterys Trojan are like michelin tires overpriced and no better than other leading brands
I used American batterys U2200 series there are ones out there that are much cheaper than trojans
some automotive part warehouse also carry them as well as most Rv dealers
38,768 PostsLatest Activity: Nov 21, 2015
