pigman1
Aug 21, 2015Explorer
I did it for a couple of years, but I put a vent line from the bottles to outside. Each bottle has an over pressure/bleed valve just under the handle directly opposite the part where you draw propane from the bottle. I put a piece of automobile water line on the valve with a hose clamp and ran the other end of the hose through a hole in the floor of the basement.
The reason I did this was that after filling, if there is a significant temperature rise or reduction in air pressure (such as caused by climbing a mountain), it can cause these bottles to bleed out some propane. With all the electrical relays, switches, lights, and other ignition sources in an RV basement, I didn't want propane and an ignition source together in a closed compartment.
It's also illegal, but the propane checkers hang out with the mattress tag checkers, so there's not too many checks done.
38,782 PostsLatest Activity: Sep 10, 2026
