rockhillmanor
Jan 12, 2019Explorer II
Common problem is the solenoid.
And no it won't click when you try to start it. It just won't start. Been there done that.
There are 4 or 5 solenoids on it. Hope its not the one on the starter unlike in the old days because now it is an assembly and you have to buy a whole new starter.
The one that seems to be the one to go out is located on the inside right front fender. RV mobile repair guys know right where to look ir's such a common problem. Easy fix, cheap part.
All you have to do is have someone check each solenoid while you sit inside turning the key. That will tell you which one is not working.
38,778 PostsLatest Activity: Jun 05, 2026
