ron_dittmer
Jan 15, 2019Explorer III
ernie1 wrote:If there are two of you, the person with the best hearing should crawl near the fuel tank. Once in position, give a yell to the other to turn the key to the "run" position, not the cranking position. Once in the run position, the person by the fuel tank should hear a quiet humming or buzzing sound for 3 to 5 seconds and then go quiet. That would be the fuel pump pressuring the fuel line.
Try this: on many vehicles there is a switch that turns off the fuel pump in case of an accident and it's located in the footwell-dash area on the passenger side of a Ford vehicle. Your owners manual should show you where it is. Check it and maybe a reset is all you need.
Turn the ignition completely off and then on again to repeat the hum/buzz.
If you don't hear anything, your fuel pump is not working. The first thing to inspect is your fuel pump fuse. Your owners manual will show you where to find it. If burnt out, swap the fuse with another fuse that supports something less important like your power windows and horn for example.
If the fuse is good, the second thing to try is what ernie1 suggests. All our Ford vehicles has one of those switches, from our 1986 Ford Taurus, 1996 Ford Ranger, and our 2007 Ford E350 motor home. I once had to reset that switch on our Ford Taurus. On our 2007 E350, the switch is located in the passenger foot well. It is behind the right-side kick panel. You can feel the switch from the top of the kick panel. You simply press it down towards the street to reset it.
If resetting the switch doesn't get your fuel pump working, there is another thing you can try to get you to a service center. I have successfully done this on other vehicles including a Chevy Express van and my Ford Ranger pick-up truck. It sounds crazy, but it has worked for me.
A 2x4 about 16" long is the ideal tool. Rest one end of the 2x4 on the bottom of the fuel tank and quickly slap the bottom of the tank. You won't dent the fuel tank that way. It can take 1 to 20 or more slaps to jolt the fuel pump inside the fuel tank to operate again.
When a fuel pump fails, it often develops a dead spot on the armature of it's electric motor. The jolting action get's the pump past the dead spot and gets it running. Once running again, DO NOT shut off the engine. Drive directly to a repair center.
Good Luck!
38,778 PostsLatest Activity: Jun 05, 2026
