RLS7201
Jul 19, 2017Explorer II
Flyteof4 wrote:
In addition, Does anyone know how to adjust the catches so you don't have to slam the doors so hard just to get them to latch?
There in lies your problem.
Don't slam the doors!
Lift the handle on the out side of the door, close door, push door with your knee to latch it. I have the very same bay doors and latches on my 95 Bounder and all the parts are original. Those plastic latches on the edges of the doors will break off when slammed.
To change the latches, first remove the handle by removing the 4 screws on the inside of the door. Then remove the gas lift spring. Then remove the latch screws and the corner screws. Then start prying the edge aluminum from the door. Not only are the doors screwed together, they are also glued together. Once the repair has been made, don't slam the doors!
