Handbasket
Nov 25, 2013Explorer
I think the Onan Microquiet 4000 has a 'prime' function built into the start switch. It's not uncommon to need a bit of cranking to get fuel to the generator if it's not been run in a while, so priming is a good idea.
Not to be the bearer of bad tidings, but if it hasn't been run for a while, it may not start even when the starter cranks it over just fine. Or it may run poorly, with the RPM rising and falling. This is the result of carburetor varnish. They need to be run for an hour or two every month or so to avoid this. If you're going to be on a tight schedule, there's not much that can be done for this issue in a short amount of time.
Jim, "I'm not a pessimist, I'm an optimist with experience."
38,780 PostsLatest Activity: Jul 20, 2026
