Maxx_Cars's avatar
Maxx_Cars
2000 harney coach ...trick to start?
I bought this a couple of years ago and it has just sat. Now I want to get it rolling but remember a "trick" was needed to engage starter while turning key. Something on the dash had to pushed/pulled/twisted...I do not know if this was a factory feature or a previous owner interrupted the start wire, Your help would be appreciated ...thanks ! [email protected]
  • I appreciate all the input.... Mr Wizard- I have 12v output from key cylinder on "start" wire. The fuse at battery on "start" wire is good, connection at battery tight. LVJ58- that is what I suspect. I do not have the total wiring diagram, but busy guy mailed me a set from TX on Friday. Keep the ideas coming.....thank you !
  • could be the key switch is bad, or could be a blown fuse or loose connection
    we have a Safari, iirc harney was built by SMC which was bought by manaco
  • If the start button in the rear works to start engine, you may have an open circuit in the 12v feed from ignition switch to the starter solenoid, just a thought.
    Best of luck & let us know when you find the fix..
  • Busy guy and bdpreece...thank you for your suggestions. Starter will not turn over at key. In order to start I turn on key and use start button at rear of coach. When I bought it I remember being told what needed to be done...and thought that it was possibly a factory design. But Busyguy has a Harney and that one starts normally. I have held key on while trying all switches and buttons on dash...no go. Yet.
  • Never crossed my mind to tell Max about that. I have an Echo charger on my engine batteries. Hardly ever use the connect switch But may be the trick he was talking about.
    Busyguy
  • Could the trick have been to push a battery boost button tying the house and coach batteries together? Not all coaches charge the starting batteries while parked and plugged into shore power.
  • Hi
    I have a 2000 Harney Renegade Classic and bought it new in Nov 1999. I don't do anything to start it except turn the key. The air brake valve will need to be pushed in after your air pressure builds up to around 100 t0120 psi. That's about all there is to starting it. It does have a preheater on the intake and your light on the dash will go out when the engine is ready to start. You may have to reheat a few time in really cold weather.
    If I can help with more info let me know.
    Busyguy
