jwmII
Aug 29, 2015Explorer
If it is anything like my Monaco it will be a plastic 3 way valve similar to the Flare it 3 way plastic valve and may even be the same thing. Ace hardware stores among others usually has these. Get 1 with the Flare it push on barb at the 3 inlets. I had to change mine and was fortunate to have enough slack in the existing lines that I was able to cut them at the old valve and with plenty of material left was able to push the lines on the valve and with Flare it stuff it is not necessary to clamp it. It goes better when pushing the lines on the valve to use a cup of hot tap water to briefly warm the line before and soften it a little before its assembly to the valve.
38,769 PostsLatest Activity: Apr 04, 2026
