- happy-2ExplorerI was told by onan rep that you never know when the pump will go out.I bought a new pump and filter from amazon took 1/2 hr to replace.works great.the pump was 45.00 so I ordered a second one and carry a spair and filter and air cleaner and oil filter.
- esyersExplorerSame problem was the fuel pump for me. Easy replacement from NAPA or Amazon. Did the filters and hoses while I was at it.
- chucl66ExplorerThanks for all the help. I have reached the end of my skills. Will get the RV shop to diagnose.
Again, thanks
Chuck - vegasfoodguyExplorer IIhttp://www.flightsystems.com/pdf/onan-rv-troubleshooing-guide.pdf
Thus should have your answer. - chucl66ExplorerThanks for all the replies.
I have checked the oil, we are at 6feet above sea level, the adjustment is for that.
Keep the help coming.
Thanks
Chuck - jyrostngExplorersomething on the unit is causing your fuel pump to not get power, when you hold down the start button you bypass the built-in protections that shut off the power to the fuel pump. oil level is the most common one.
- fischerExplorerAt what altitude are you camping ? Most have a a adjustment by the carb.
- jsmartExplorerHad a similar issue with my Onan 5500, replaced both fuel filters and the fuel pump, that was 6 months ago. I exercise it monthly on full load, hasn't quit yet.
- OLYLENExplorerFuel filter or fuel pump.
LEN
38,769 PostsLatest Activity: Apr 05, 2026
