Gjac
Feb 27, 2021Explorer III
Check your ride height first, how much space do you have between the upper a arm and lower stop? Now jack up the front end and fully inflate the bags. Lower the jacks and check ride height again, if you don't see 1.5 ins or more I would then replace with the HD springs. I had no more than 1/4 in so I went with the HD springs from Henderson also, and it fixed the ride height. I have seen several P-30 front end where they were just resting on the stops. Also resist the temptation to put in heavier springs than required thinking more is better, this could lead to more force on the upper A arms causing stress cracks.
38,782 PostsLatest Activity: Sep 10, 2026
