dougrainer
Apr 05, 2016Nomad
nancyjerry wrote:
If it clears up anything. The power indicator light on the control panel on the front of the fridge goes off. Open door and there is no power to interior light. 24-48 hours later control panel light and interior light comes on, refer cools, freezer makes ice, for 36-48 hours. We have turned it off and will get mobile service to come out and check it. Batteries are not the issue.
Sure sounds like it is in that 48 to 54 hour shut down defrost mode. Have you tried to check after 2 to 3 hours after you notice it is shut OFF? But, the front LED indicator light should stay on in that mode. What needs checked is, when it shuts down, you need the 12 volt power TO the back of the refer checked. See if you still have 12 volt supply power and if so, does it go thru the recall box. Also, I wonder if the Flue cover SNAP DISC is still installed. If so, it should be removed. That was the original overheat sensor and when the recall box was installed, that snap disc was either removed or bypassed. Doug
38,782 PostsLatest Activity: Sep 10, 2026
