hottubkid
Jun 03, 2016Explorer
If you put the meter on ohms and go from ground to power, won't you blow the meter? Better checking voltage. With first one lead to good ground and then the other lead to different power sources and then put lead on good power source and other lead to each ground. With meter on 12volts dc
38,768 PostsLatest Activity: Nov 21, 2015
