GPWayne
Jun 03, 2016Explorer
I should have been clearer about using a volt/ohm meter. Turn the meter to DC volts (range higher than 12 volts) When looking for power. If you do this first you will be safe to start looking for a ground......When looking for a ground use the ohms setting.
As Hottubkid said, If you put voltage across an ohm meter you will damage the meter.
I was assuming that if you owned a volt/ohm meter you would know how to use it.
38,768 PostsLatest Activity: Nov 21, 2015
