SCVJeff
Oct 26, 2014Explorer
This is a MUCH better description...
As you've probably noticed, that cover is heavy. You might want to think about installing a handle on it. Likely the ripped rubber is the folks working on the engine are butterfingers. When that thing comes down not lined, it could cut it up.
I have heard about the back cap before. I would suggest posting the cap question on RV Forums and iRV2 where there are Winnebago specific forums. You will likely find a fix already done.
For the open box end under the bed, if you are referring to the access hole on the right side, that's normal. For one thing it provides cooling for the inverter, and cabin heat for the wet area (fresh) on mine. If the left side is open, then you are missing a maintenance plate.
