Sam_Spade
Jun 12, 2017Explorer
SNOPRO711X wrote:
I am leaning towards a bad ignition switch. Tomorrow I will see what the Freightliner dealer has to say.
Worn brushes on the starter motor can do that too.
As can loose or corroded battery cable connections.
Also burnt contacts on the solenoid.
Having a meter connected at the starter when it fails can tell you a LOT about what the cause is. IF good voltage appears at the starter but it doesn't run......that's a bad starter.
38,782 PostsLatest Activity: Sep 19, 2026
