Gjac
Nov 26, 2015Explorer III
CoachFiver wrote:Just to be clear when you removed the cable you were able to shift the lever on the transmission into all of the gears, but the cable does not extend far enough to move the lever into the two lower gears(1st and 2nd) is that correct? Were you able to adjust the cable end to reach 1st gear?
So it turns out that the linkage cable doesn't allow for enough cable travel movement for the lever to move from park to first. Not sure if it is an aftermarket cable that was the wrong one or if it just was never adjusted properly.
Going to try to adjust the ends to make it still work to reach park and then be able to reach 1st.
