tropical36
Nov 26, 2015Explorer II
CoachFiver wrote:
So, yes when linkage is disconnected, the lever on the transmission will go thru all gears, park, r, n, od, d, 2, 1. When the column mechanism is disconnected from the linkage it will also go thru all gears.
It seems like it might be aftermarket linkage. By my measurements, the linkage cable should have 4" of travel from park to first.
My linkage cable seems to have 3.25" of travel.
Need to start investigating if there is different cables with different travel.
I think you got to the root of the problem and some people always do things half as......
You should be able to find an OEM replacement online, without paying dealer prices.
