Second_Chance
Jul 26, 2020Explorer II
What's the model number of the fridge? Are you sure it isn't LP/AC? In either case, even on LP, the fridge requires 12 volts DC to operate the control board and gas valve. It sounds like the fridge isn't getting 12 volts when the motor is not running. You likely have a separate house battery (separate from the battery for starting the motor). Is it in place and charged? If you bought the motorhome used, it may have come without a house battery in it. Finally, an absorption refrigerator needs to be fairly level to operate - but out of level won't cause the issue you're seeing.
Rob
Rob
38,783 PostsLatest Activity: Sep 24, 2026
