tobydad
Nov 21, 2017Explorer
The red key must be on in order to have electricity going into the batteries or out of the batteries. If the key is on and voltage tester shows less than 13 volts going into the house batteries with the engine running, then the first thing is to check that the battery terminals are clean. Use a wire brush to clean both the terminals and the cable connections. Then check with voltage tester again while the engine is running. If still not charging then check what BruceMc said above.
38,780 PostsLatest Activity: Jul 05, 2026
