rgatijnet1
Apr 18, 2015Explorer III
Usually the chassis/engine battery is NOT a deep discharge type of battery since it is not supposed to be drained like your house batteries. Your owner's manual should tell you what type and size of battery to use.
You should keep a trickle charger on the engine battery at any time when the coach is not being used since there are several things that will be drawing a slight amount of current on a continuous basis.
If your batteries were allowed to discharge, the engine computer may be giving some false information that will change once the engine is started and the electronic control module goes through the reset procedure.
