mikmazz's avatar
mikmazz
2003 Winnebago Ford f53 fuel pump help????
We have a 2003 winny on a f53 chassis. The fuel pump is bad and needs to be changed. A truck shop quoted me 17 hours of labor. Obviously I told them no, i'll do it my self. After crawling up under this RV The gas tank is in the rear center and it F'n huge! The problem is the rear leveling jacks have a cross member in the way that has to come down and be moved out of the before un bolting/unlatching the tank.. Is there an easier way of changing this pump? Like, did they install a hidden door in the floor of the RV to gain access to the fuel pump? Or are there any tricks, I dont have the heavy duty equipment to get this tank out..Any ideas or advice would be appreciated.. Ive already drained the tank using an inline cheap fuel pump to remove the fuel. The tank is steal and looks to be very heavy duty..
Regards,
Mike
