Heathrm
Nov 09, 2021Explorer
MountainAir05 wrote:
Looking at those code, I get that you have a electrical issue along with fuel system. Most of those codes are generic so not the issue. You did not state on the battery charge as in full 12.8 volts. Did you recalibrate the new pedal assembly. A lot of thing go South when something set sometimes.
First you need to check fuel, air and spark. Throwing parts at generic codes will cost you a lot of time and money. The smoke is either water or oil which could be several thing. Too much fuel can cause a lot of smoke issues.
The battery was charged prior to any attempt to start. Also, I didn't know you had to calibrate a hew pedal assembly. I will look into the process. thank you.
38,782 PostsLatest Activity: Sep 10, 2026
