tiredkid
Mar 25, 2014Explorer
btilfan wrote:
Will check to see if the tube swivels. As it stands if I remove the cap it exits two inches from the tail pipe I would not be able to attach anything to it and no room for the slinky to exit from it.
Ok so u don't have a wet bay like most larger diesel pushers class A have then? If it don't swivel I would cut it off and use a inline connector and reglue it together correcting the angle needed to clear this lip and if need be add a 90 to it
or is it the exhaust pipe excites right under the wet bay?
38,706 PostsLatest Activity: Feb 03, 2025
