Berner2
Mar 25, 2014Explorer
It sounds like the same set up as my Coachmen. The outlet is directly above a four inch piece of abs that is curved and extends about 18"-2' and has a screw cap like a sewer clean out. My pipe swivels and I assume yours does or will with a little persuasion. The abs also has a sewer clean out cap on it which attached to the coach with a small cable so it doesn't get lost. If the cap is gone you can get them at Lowes, Home Depot etc.
I have a short 3'-4' piece of crinkle waste hose attached to the outlet with a regular female twist connector and it extends down the abs tube. The end that exits the tube a has a male twist connector, only the male end will slide through the tube, so that I can attach my sewer hose to it beyond the end of the abs.
It seems like an odd set up but actually works pretty well. When I'm done dumping I disconnect the long hose and push the short hose into the abs piece and screw the cap on.
I believe I had to remove the abs piece to make it easier to shove the crinkle hose through it and the reinstall it. This also a good time to make sure the abs elbow will swivel.
I hope this is clear, but if it isn't pm me and I'll text you or e-mail you a picture. I'm not smart enough to post one on here.
38,766 PostsLatest Activity: Jan 10, 2026
