Berner2
Mar 26, 2014Explorer
Bumpyroad wrote:btilfan wrote:
Thank you berner2, I checked it out and it does swivel I will get a male fitting and give your set up a try. did you have to use an angled end to have the short slinky go into the top of the abs without crimping it?
when I mounted mine on my bounder the stinky slinky just went straight down around the 90 degree bend and out the end of the black ABS pipe. I left the stinky slinky as long as it would compress back into the pipe and just added additional lengths on as needed.
bumpy
It was just like Bumpy said as I recall. I do believe I had to remove the abs piece from the swivel attachment to make it easier to attach the female twist fitting to the dump outlet. I had very little room and I don't think there was enough to get the hose down the pipe without first removing the pipe......hmmm, make sense!?!?
38,766 PostsLatest Activity: Jan 10, 2026
