Big_Katuna
Aug 06, 2015Explorer II
I'm sure its a C-7. I have an 05 Fleetwood.
Check with CAT on oil capacity as most mechanics will put 22 qts in but CAT says to ony use 19 to prevent excessive oil spewing out the crankcase slobber tube and clogging up your radiator which will be pricey to fix.
Also the tube should be extended back past the radiator if it hasn't already been done.
All fluids are supposed to be changed every five (except Allison after its been changed 1-2 times, I forget).
Differential, power steering, hydraulic, engine oil, air system desiccant, all filters, belt and hoses. and coolant. Check front hub seals for leakage which will ruin your brake pads.
Good to go. Only $3000.
