- RoadHound_RVerExplorerMine is a Power Gear. Did you try calling Holiday Rambler. You have a vin and they have the specs.
- ArchHoaglandExplorerOn my Monaco La Palma, that has a HR emblem on the front cap, the bedroom slide assembly is a Power Gear.
I had the drive gear break a tooth on mine and it caused erratic operation. A local Dealer had the correct gear in stock but did mention it was hard to get parts for Power Gear assemblies sometimes. - Odds are, it is either Powergear or LCI. IF the motor is under the bed cabinet, you will find a name on the motor. If the system is a cable slide, then it is an Accuslide system. Doug
38,759 PostsLatest Activity: Jul 19, 2018
