oldgulfc's avatar
oldgulfc
2004 itasca sunrise Toilet parts
Hey All, I upgraded to a 2004 class A itasca and the toilet valve is leaking by and filling the bowl to over flow. All I can find is CHH in big letters towards the back on top. I can't find any info to get parts. Any ideas ?
  • I took the old one out and it wasn't worth saving. Ended up taking F-troups advice and got a dometic 310. Will hopefully be easy install this weekend. Thanks again to all for help.
  • 4x4van's avatar
    4x4van
    Explorer III
    Sounds like a previous owner may have replaced the toilet with something non-standard. My '04 Itasca uses the Sealand Traveler Lite 100, and I see no "CHH" toilets in any Winnebago Itasca parts lists/catalogs.
  • Thanks for all the great replies. I will do some more searching with the new tips.
  • Jayco-noslide wrote:
    Call Winnebago with your units ID number and serial number and I bet they can send it to you as they keep all parts even for old units.
    I'll bet he can go to winnebagoind.com amd find the info in the Resources tab.
  • Call Winnebago with your units ID number and serial number and I bet they can send it to you as they keep all parts even for old units.
  • Pull the toilet if it has a standard closet ring take a look at the RV Domedic 310 series 18" tall and super flush china bowl for under $200. JMHO
  • replace with something standard, if no one rings in. Maybe Doug will drop thru later. I also do not find anything.
