bobndot
Sep 06, 2018Explorer III
zidjan wrote:BruceMc wrote:
If you have a newer unit, check your thermostat's fan setting. It should be on Auto, not high or low.
I was twiddling with mine some months back when I had the same issue - my thermo was set to low, which means the fan runs all the time.
Here's a pic of one similar to mine:
Oh that's interesting, OK I'll play with it tonight and report back..thank you
Yes, I think 'auto' is the normal position that the thermostat needs to be in. Check the install directions that came with the thermostat that you installed.
