rgatijnet1
Jul 24, 2014Explorer III
wa8yxm wrote:
Mine did that too.. Turns out there is a Technical Service Bulletin out on them, this is not a recall since it is NOT a safety issue.. But what it means is if you take it to a authrized service center you just might leave happy.
As i said,,, Mine went out.. ON THE WAY to said authorized service center :).
I did not even have to make an appointment to get it fixed, Just and "Oh, by the way, on the way here....."
Since the OP's coach is a 2004, it would be subject to the recall, 50402-C, that was a safety recall since it affected the calibration of the Actia dash that affected the ABS system. This recall was for 2003 and 2004 Workhorse chassis RV's. There may have been a TSB for later year coaches but the OP should first check to see if the recall was performed on his coach, which can be found by entering his VIN number at the Workhorse registration.
38,769 PostsLatest Activity: Apr 03, 2026
