Big Katuna wrote:
Sounds like your off to a start. Did you do the 2nd fuel filter by the leveler pump?
Actually that is the only one I did, I did not notice the one up on the engine because until a few minutes ago I had not taken the floor up in the coach to look over the engine and discovered the other filter. I should have know it had 2 I have a 3126 Cat in an old bucket truck I have and it has 2 the same setup. I will have to pick up another filter.
I got my slobber tube extended. I took back the roof cleaner and picked up some Murphy's oil soap. I think I may do the Eternabond tape after watching some videos on the slides and front and back main seams as well as all the penetrations in the roof.
I got some clear sealant to do the other areas from a local RV repair shop I have done business with on past RV's.
