larry cad wrote:
Personally I would avoid RV with a Cat engine. Cat got into the RV business back around 2005 and failed terrible, then got out as quick as they got in. The engines are bad, but service is. This is why you will see so many RVs for sale at low prices, with Cat engines
Sorry, but you must be confused. I have had predecesors of the C7s (3126) from 95, 2000 and now a 2005. CAT has been in the business forever. The C9 and the C7 are both great engines, as a metter of fact, they are considered the best engines.
The only issue on the C7 is the HUEI pump. It is very sensitive to oil changes and bad fuel.
My only concern would be that it does not have enough miles. It sat all its life. That is normally a bad thing because everything dries up and you get leaks and blo up hoses.
