Big_Katuna
Dec 26, 2013Explorer II
2005 Freightliner engine info panel check engine UPDATE
So a month or so ago the check info panel light lit up for a few seconds.
It has done it a few times for no more than a second. Always cold, never when it has warmed up. All analog gauges are normal.
So today, the check info panel lit up while it was warm and stayed on over a minute then went off. About 10 minutes later the check engine light came on.
Full Power, analog gauges fine, light goes off after 3-4 minutes.
Drove normal the remaining ten miles to the campground.
Any one seen this?
Guess Ill be calling and visiting FL next year.
Added about half a gallon of distiller water to the tank and no more warning lights
Thanks all.
Any one seen this?
Thanks all.
