Ralph_Cramden
Sep 09, 2017Explorer II
Old-Biscuit wrote:
Appears you have a 32 gallon fresh water tank and a 6 gallon water heater.
It is what it is...regardless of published numbers
Exactly.
Every advertisement, website, or brochure from an RV manufacturer comes with this disclaimer or something similar.
" All information in this brochure and on www.jayco.com is the latest available at the time of publication approval. Jayco reserves the right to make changes and to discontinue models without notice or obligation."
Many people have went and looked on a dealers lot at an in stock unit and then had the dealer order one from the factory. Its quite the surprise when that ordered unit arrives and has different capacities, a different sofa, a wrap around dinette when the one looked at had slide in, etc etc etc. Usually by that point the dealer can say "gotcha" as the buyer did not get the deposit qualified as refundable. That language is there for a reason, and its only a CYA for both the manufacturer and the dealer.
When the OP's 2005 was on the line, they could have ran out of the correct tanks with the advertised capacity. In that case they throw in whatever they have that will fit, and keep the line moving.
