Rick_Jay
Jul 19, 2019Explorer II
Well, if the fuses & breakers are all OK, it sounds to me like you lost a 12V power connection (or multiple connections) and/or ground connection(s) to that slide. Is the slide electric or hydraulic? I know nothing about the construction of your motorhome and slide, but somewhere there is a wire or wire harness which brings power to the slide from the stationary part of the coach. Hopefully someone familiar with your layout can direct you where to look. If you have a DMM (digital multimeter) it would be helpful to make measurements to see if the +12V power or the ground or both was lost at the slide motor and the bedroom lights which are not functioning.
Good Luck,
~Rick
Good Luck,
~Rick
38,780 PostsLatest Activity: Aug 05, 2026
