Chum_lee
Jun 22, 2019Explorer
Since you tow (pic from your sig line) you are putting the transmission fluid under more stress than if you didn't. If you changed the fluid at 30k, I wouldn't worry about it right now. Go, have a good time, and, take care of it when you get back. It's not as if the fluid is good at 60k, then bad at 60,001 miles. It's a progressive thing. Unless the transmission is shifting badly, the, fluid smells burnt, and it is off color, (brown instead of red) you should be OK. Just don't continue putting it off, just because everything seems OK . . . . . at least for now.
Chum lee
Chum lee
38,782 PostsLatest Activity: Sep 10, 2026
