tropical36
Mar 23, 2019Explorer
jolooote wrote:
Fixed it, but since there was no interest there is no need to explain.
Just saw you post and thought the relay in question was for tying the two battery banks together. This should be automatic and also controlled by a boost sw. on the dash.
Only other thought, was for a battery bank being under some load and once it was recharged, it was closing to allow the other bank to charge.
However this shouldn't be all that much, save a bad battery, so maybe a loose wire on the solenoid coil or like problem.
I've had the same no response on occasion, but still came back with my solution........and yes, someone is reading and benefiting from it. In your case, there's been 125 people, so far.
38,766 PostsLatest Activity: Jan 10, 2026
