Gjac
Aug 16, 2017Explorer III
Is it attached with 4 screws? Can they be tightened or are the stripped? If stripped you my have water intrusion through the screw holes which rotted the underlying sub structure. If so a backing plate or larger longer screws would be required ti fix it. Also seal the attach flange and screw hole with caulking.
