Rolin
Sep 29, 2021Explorer
2006 Sunova 12V ground problem.
DC power status:
- Chassis battery is 12.6Volts
- House battery is 8.5V
Troubleshooting information:
1. Very low current from charged chassis battery to engine and gauges. Gauges light (barely) and engine will not turn over.
2. Converter/battery charger does not charge house batteries.
3. With external battery boost to house batteries the generator will not turnover.
It appears that all batteries are grounded to a buss bar welded to the frame.
I assume that the chassis frame is common DC ground for Engine, Generator, and Converter.
I tried using a jump cable to ground the batteries to another spot on the frame. It seemed to help a small amount. Could get the generator to turn over but not enough current to turn the motorhome engine over.
I would appreciate any ideas or suggestions you might have.
